Online Physical Properties of Compunds
Guest
Can some point me in the direction of online sites etc that have databases of physical data about any product.
Also MSDS (i found some but they are not very useful)
Looking for something like CRC handbook and Perry tables all rolled into one search system with MSDS attached
Good luck. Back in 1998 I tried searching for a similar source to populate some data tables we were putting together for a new plant. We ended up using Perry's, the CRC, and a couple of college textbooks.
You can try getting abstracts from the internet on individual materials, but back in 98 they made you pay dearly for the info. SteamJetPE
Ejectors, LRVPs, Hybrids
Troubleshooting, startup, design
hi
the physical properties side on the net is bad but the CDC (NIOSH - national institute...occupational safety and health or something like that) in the USA has some info which is usefuly for MSDS.
check it out at
then use the search engine
eg of the info supplied
NIOSH Pocket Guide to Chemical Hazards
Phosphorus trichloride CAS 7719-12-2
PCl3 RTECS TH3675000
Synonyms & Trade Names
Phosphorus chloride DOT ID & Guide
1809 137
Exposure
Limits NIOSH REL: TWA 0.2 ppm (1.5 mg/m3) ST 0.5 ppm (3 mg/m3)
OSHA PEL†: TWA 0.5 ppm (3 mg/m3)
IDLH 25 ppm See: 7719122 Conversion 1 ppm = 5.62 mg/m3
Physical Description
Colorless to yellow, fuming liquid with an odor like hydrochloric acid.
MW: 137.4
BP: 169°F
FRZ: -170°F
Sol: Reacts
VP: 100 mmHg
IP: 9.91 eV
Sp.Gr: 1.58
Fl.P: NA
UEL: NA
LEL: NA
Noncombustible Liquid; however, a strong oxidizer that may ignite combustibles upon contact.
Incompatibilities & Reactivities
Water, chemically-active metals such as sodium & potassium, aluminum, strong nitric acid, acetic acid, organic matter [Note: Hydrolyzes in water to form hydrochloric acid and phosphoric acid.]
Measurement Methods
NIOSH 6402
See: NMAM or OSHA Methods
Personal Protection & Sanitation
Skin: Prevent skin contact
Eyes: Prevent eye contact
Wash skin: When contaminated
Remove: When wet or contaminated
Change: No recommendation
Provide: Eyewash, Quick drench
First Aid (See procedures)
Eye: Irrigate immediately
Skin: Water flush immediately
Breathing: Respiratory support
Swallow: Medical attention immediately
Respirator Recommendations NIOSH
Up to 10 ppm: (APF = 50) Any self-contained breathing apparatus with a full facepiece/(APF = 50) Any supplied-air respirator with a full facepiece
Up to 25 ppm: (APF = 2000) Any supplied-air respirator that has a full facepiece and is operated in a pressure-demand or other positive-pressure mode
Emergency or planned entry into unknown concentrations or IDLH conditions: (APF = 10,000) Any self-contained breathing apparatus that has a full facepiece and is operated in a pressure-demand or other positive-pressure mode/(APF = 10,000) Any supplied-air respirator that has a full facepiece and is operated in a pressure-demand or other positive-pressure mode in combination with an auxiliary self-contained positive-pressure breathing apparatus
Escape: (APF = 50) Any air-purifying, full-facepiece respirator (gas mask) with a chin-style, front- or back-mounted canister providing protection against the compound of concern¿/Any appropriate escape-type, self-contained breathing apparatus
Exposure Routes inhalation, ingestion, skin and/or eye contact
Symptoms Irritation eyes, skin, nose, throat; pulmonary edema; eye, skin burns
Target Organs Eyes, skin, respiratory system
See also: INTRODUCTION See ICSC CARD: 0696 See MEDICAL TESTS: 0191
Making a physical handbook is _a lot_ of work, and im not surpriced its not there. Many vedors do however supply information re. the compounds that they sell.
So try to search for something specific on e.g. google and look out for know vendor - or go directly to a vendor site and search here.
Best Regards
Morten
you might try chemfinder.com This has some information for you too. I do agree with Morten. The company that produces the chemical is the best source and I believe DOT requires an MSDS for a chemical shipment.
Good luck
Frank
