Road Impact On Tires
Timms
25
Hi
Does anyone know if there have been tests done on tires to determine the coefficient of restitution at different speeds, with different masses? If so where can I get this kind of data? Or, should I be treating the tire as if it were a spring and determine its k value? If this is the case is there published data for k values of tires?
Take Care :)
