GregLocock
Automotive
- Apr 10, 2001
- 23,449
Is it normal for the yaw moment coefficient to be negative in sign, and all the others are positive, assuming SAE conventions for axes? This is for a conventionally shaped sedan. It seems reasonable (ie the car weathercocks) but I want to be sure.
Also, where is the reference location usually situated in most wind tunnel software, for the single point method? I'm guessing half way between the axles at axle height, but that is only a guess.
Finally, what is the meaning of the yaw moment coefficient, CYM
After all, a torque of 1/2 CYM rho v^2 A is dimensionally incorrect, so that equation needs to be modified.
Yes I know I should look it up but the books are elsewhere.
Cheers
Greg Locock
Cheers
Greg Locock
