aspearin1
Chemical
- Nov 5, 2002
- 391
I am investigating the option of using electrostripping to remove a nickel alloy coating. Right now, we use strictly a chemical strip process. My thinking is that if I can continuously strip and plate my nickel to a getter cathode, then I can prolong the life of my acid by keeping a low equilibrium of dissolved metal ions. Does anyone have experience with this? (Also known as reverse plating.) Thanks in advance.
ChemE, M.E. EIT
"The only constant in life is change." -Bruce Lee
ChemE, M.E. EIT
