Running macros with worksheet protection
Engineeeeeeeeer
TH
Some of you may remember I have made a spreadsheet to keep a championship table. I will be handing this over to someone in the club, and I want to make sure that they do not accidentally click on a cell containing a formula (which needs to be visible all the time) and deleting the data/formula. (The user is not too proficient in the use of excel (less than myself), but can input data).
I have made three macros (record macro), one to sort by Championship position, one to sort by name, and one to sort by riding number.
The problem I have is that to be able to run a macro, the password (for the worksheet protection) needs to be typed in. The macros have been made in such a way that they lock the worksheet again, however it does mean that the user (inputer) has to have the password. After you have run one macro, subsequent running any macros to not require the password to be input again.
Is there a way to overcome this problem - for instance is there a way to protect the worksheet, but allow the user to run macros without inputting the password? Or any other ideas?
Thanks in advance.
If I understand your problem then try this to protect the worksheet
Worksheets("Sheetname").Protect("password")
This protects the sheet with a pasword and requires it to be entered by the user to unprotect the sheet.
You can unprotect the sheet in macro by replacing Protect with Unprotect. Therefore protect and unprotect the sheet as required in the macro without the user ever knowing the password
You could unprotect the sheet in code on the appropriate event and then reprotect at the end of the macro:
Code:
Sub Macro1()
    ActiveSheet.Unprotect
' Rest of your macro here
    ActiveSheet.Protect DrawingObjects:=True, Contents:=True, Scenarios:=True
End Sub
Good Luck
johnwm
________________________________________________________
To get the best from these forums read faq731-376 before posting
Steam Engine enthusiasts:
