shearstrength
I am one frustrated SW user.
Copying Components "Solidworks 2001"
I would like to know how to copy multiple components when working in an assembly?
For example, if I have a bolt, (2) washers, lock washer, and a nut to be used in a different location other than a linear direction, how can I choose these items while containing their mates between them? I don't want to copy one component at a time and have to remate each component. This would obviously be a waste of time.
Mirroring Components "Solidworks 2001"
I would like to know how to mirror components while working in an assembly?
For example, I design a left side system, and I want to mirror/copy components maintaining their mates. How do I do this? I've tried the "INSERT", "MIRROR COMPONENTS" from the menu but the result I get is that the components are mirrored but without their mates, so the components float in space independantly from each other. I thought a sophisticated software like Solidworks was suppose to save designers time. In this case if I have to go back and reissue mates on all of these components, where is the time saved?
Any response will be greatly appreciated!!
