jboetto
- Jun 14, 2002
- 2
I have a small contact (.042" outside dia x .00175" wall x .009" wide)standing on the cylinder surface. If a parallel mating surface came down, once it started to displace the contact, what are the predicted reactionary forces and do I exceed the elastic limit? The measurements need to be calculated @ .0005" steps from .042" to .036"
The material is Be Cu 25. Please advise
