bagnamento
Nuclear
- Feb 23, 2005
- 30
Hi everybody,
a colleague of mine asked me if, when A_N.° is an essential variable for welding procedure qualification and no filler metal is used, the molten base metal should be considered as weld metal and its chemical composition be determined in order to determine A_N.°
I believe that A_N.° is not a concern if no filler metal is used.
What do you guys think?
