Accessing Excel Range from PowerPoint
Rebam98
Computer
Mar 28, 2006
14
Hi-
I'm working on something and cannot for the life of me figure out why it won't work.
I need to pull in a range of cells from Excel into powerpoint, to complete a presentation. This is the code I have. It's not complete because I have been stepping through the code until I get to the end, and it give me the generic '1004' application or object defined error.
The problem comes in selecting a range in Excel. I can get cell "A1," i.e. a single cell, just fine but when I try to define a larger range, it crashes. I've racked my brain for every possible thing I could do. I tried setting up a named range and referencing it (in the commented out code below) to no avail.
The code below is a little simpler than what I am doing, to isolate out the main problem. Basiclaly I just need to be able to pick out a range of cells in Excel from PowerPoint.
Please help.
sub get_excel_range()
Dim amberwrkbook As Excel.Workbook
Set amberwrkbook = GetObject("H:\Notes\Learning VBA\Making Summary to play with.xls")
amberwrkbook.Application.Sheets(24).Range("A1").Select '<-- works just fine
amberwrkbook.Application.Sheets(24).Range(Cells(1, 1), Cells(8, 8)).Copy '<-- CRASH, FAIL BURN!
'amberwrkbook.Application.Names.Add "Summary_Sheet", Range(Cells(1, 1), Cells(8, 8))
'amberwrkbook.Application.Sheets(24).Range("Summary_Sheet").Copy
End Sub
The catch is that you have properly referenced the context of the Range, but not the context of the Cells objects. So that is what fails, because VBA will try to find it in the Global context. This works in Excel VBA, since the active workbook is always in that context. What you need to do is the following:
Code:
Sub GetExcel()
    With amberwrkbook.Sheets(24)
        .Range(.Cells(1, 1), .Cells(8, 8)).Copy
    End With
End Sub
don't forget to put the . (dot) in front of each Cells statement.
Cheers,
Joerd
THANK YOU SO MUCH!! I never had to put the . when using Excel so I guess I didn't know ...
