1
- #1
I am looking for some direction in finding documentation regarding lifting trunnion design for pressure vessels. In particular, I'm trying to educate myself on the common practices involving lifting trunnions. My company generally utilizes lifting "lugs" when practical, however, we have a client whose spec requires "trunnions" on all vessels over 5 metric tonnes in weight. An example of one of their vessels is a 72"I.D. vessel, 20' long, approx. 56,000 lbs. with 16"-Sch80 trunnions. Reasonable or overkill? Now, this vessel will be hoisted onto an offshore rig from a barge and the lifting devices are to be designed with an impact factor of 4. Where can I go for information regarding good/standard engineering practice for lifting trunnions. I'm not doing the design on this project, I just want to gain some insight for my own piece of mind. Books? Website? Applicable ASME Code?
CW
CW
