Add materials to Cosmos Express
overkill04
CA
Hi all
Is it possible to add materials or material properties to Cosmos Express.
I want to input some Yield Strength values for PVC so I can analyze some forces because Cosmos tells me that it doesn't have a yield strength value for PVC.
Thanks for any help you can provide.
Overkill
Cosmosexpress won't do non-linear analyses so it's waste of time putting in a yield strength value.
corus
CosmosXpress uses SolidWorks & Custom Material List, so you can apply a material either from the tree (edit Material) or if you haven’t assigned a material, CosmosXpress will ask you to assign a material when you start your analysis.
Hope this helps!
