Compressibility value of Jet A1 fuel 3
HVAC68
418
I would like to know the compressibility value of Jet A1 fuel. Can somebody help please.
HVAC68
Although I cant tell you the value for Jet A1, I had to find the value for diesel many years ago and I contacted Exxon directly, they had a marketing centre in London that put me in touch with a lab, they had all the values for all their fuels and lubricants although it wasnt a standard test. A quick check for any fuel supplier on the web might get you a contact as I have lost mine now.
I agree with monaco8774, the best source for data is the kerosine supplier itself.
To have an idea of the values and assuming it to be a mixture of hydrocarbons centering at C10-C12, the figures for isothermal liquid compressibility -(1/V)([∂] V/[∂] P) at 25oC for n-paraffins given by the CRC manual in 1/MPa, are:
C9 11.75 [×] 10-4
C10 10.94 [×] 10-4
C11 10.31 [×] 10-4
C12 9.88 [×] 10-4
C13 9.48 [×] 10-4
This one works quite well. It calculates E, the bulk modulus for hydrocarbon liquids. To get "compressibility" divide 1 by E.
E = 100000* exp(1.9947 - 0.00013427 * TempF - 0.79392/SG^2 -0.002326* TempF/SG^2 )
Per API's latest MPMS, the volumetric correction factor for effects of pressure on liquid (CPL):
CPL=1/(1-(10^-5*Fp*P))
Fp=exp(-1.9947+.00013427*TempF+(793920+2326*TempF)/SG^2)
P=psig
SG=specific gravity at 60 deg F
DB
Hey! That's the same formula for bulk modulus, except its not multiplied by 100000.
