WILDWINGS27
FOR A NORMAL SANITARY SEWER, I NORMALLY SPEC. A PVC PIPE ACCORDING TO ASTM D-3034 WITH ASTM D-3212 JOINTS. HOWEVER, WHEN CLOSE TO A WATER MAIN, I HAVE BEEN TOLD THAT I CAN USE THE SPEC ASTM D-2241 WITH ASTM D-3139 JOINTS FOR LOW PRESSURE APPLICATIONS. HOWEVER,WHEN I LOOK AT THE ASTM SPEC.,IT DOES NOT SAY WHAT THE PIPE ACTUALLY IS, JUST THE TESTING METHODS. I KNOW THAT USUALLY SANITARY SEWER IS SDR 26. BUT WHEN I SPECIFY THE LOW PRESSURE PIPE, WHAT IS THAT? IS IT SDR 23.5?
I GUESS I AM LOOKING FOR SOME CLARITY WHEN I TELL CONTRACTORS WHAT TO INSTALL. WHAT IS THE DIFFERENCE BETWEEN STANDARD PVC SANITARY SEWER FROM LOW PRESSURE SANITARY SEWER, TO FULL WATER MAIN PVC? IS IT JUST A DIFFERENCE IN THE THICKNESS (SDR)? OR IS IT SOMETHING MORE?
