kikiturbo
- May 12, 2005
- 14
Hi, I posted this in the Solidworks section but was instructed to post here as this might be more appropriate section... here it goes..
Hi, I am just starting using SW 06 and am having some problems with modeling and analysis of a spaceframe construction for the car I am making.. as I want to model it in SW and analyse its torsional stiffness properties...
now, the easiest way for me is to use a 3D sketch and make my tube frame, then use the weld profiles tool and assign each section of the sketch with a tube.
now, when I do the analysis in COSMOS it doesn't understand that the tubes are actually connected togeather, so there are two ways of doing it, that I see:
1. use fillet welds and weld the tubes in SW
2. use the restraint tool in COSMOS and "tell" cosmos that the tubes are rigidly connected in the frame..
the first solution doesn't always work, in fact once I have a real 3D spaceframe, where I have joints with several tubes going in, the SW fillet weld feature just will not weld some tubes togeather...
the second solution is very time consuming, and makes COSMOS block and crash from time to time...
I have also tried exchanging the tubes in the model with solid bars of equal cross section area (as I presume that tension/compression of the tube will have much greater influence on the frame torsional stiffness than tubing bending) that does make it much faster but the problems persist...
does anyone use SW and COSMOS to model tube frames and analyse it's properties... care to share some tips? or should I look for other software...?
best regards
vlado
best regards
vlado
