ankledeep
Agricultural
- Jul 12, 2006
- 9
Good in electronics and telecom, new to BIG 3 phase motors!!
I have an ag well pump.... 100 Horsepower 480 3 phase "part wind" (6 wire) motor with a "starter" (just 2 big contactors really) one has a phnumatic time delay adjustable from 0 to 40 seconds(as found set to 0.1 seconds)unit is 12 years old. Both contactors have one phase melted open and 2 phases welded shut!!! Haven't meggered the motor yet.... My question: should the 1st contactor close then , 3 or 4 seconds later the 2nd contactor close, (the way the pump on my farm works)or should both contactors close at the same time??? And if the timer was not set correctly, would that have possibly caused the contactors to burn up???? (I found an old contactor in simular burnt up condition laying in the bottom of the control panel!!!)
