Custom Mist Elimination Pads
cdrras
I currently am designing a gas-liquid separator and I'm trying to find a manufacturer that specializes in custom mist eliminators. Because my separator is very size constrained due to the application it will be used for, the dimensions for the separator are roughly 3.25" ID diameter and roughly 16.25" in length (plus outlets and what not). Does anybody know of a manufacturer/suppliers that specializes in very small mist eliminators that I might be able to use or any custom-made mist eliminator manufacturers that could manufacture one to a certain size??
Traditional mesh blankets constructors are: Yorkmesh, Tissmetal, Vico-tex, Knitmesh and Fleximesh. If your application is for low temperature service you can use Teflon mesh, which withstands temperatures up to 120ºC and has good corrosion resistance.
Hope it helps
Luis
The temperature of my streams is only 35 Celsius for both the inlet and outlets. I'll look into these places you suggested, and hopefully they do custom designs. The places that I have found so far that DO custom design, primarily do it for large scale industrial applications. The dimensions I am looking for are 3.25" in diameter and 4.00" in depth. Thanks for the advice.
