Cayroo
- Jan 16, 2003
- 15
I am trying to find a current table that gives the allowable shear per anchor bolt with multiple bolts under shear walls in the wood to concrete contection. It used to the called out in an old UBC and is not even listed in the NSD. Beyer's book gives a formula and tells you to use the multiple bolt factor in the sill plate but it doesn't tell you where it comes from, the NSD has wood to wood table, wood to steel, but no wood to concrete. Woodworks uses the value of 1.0 in its program, is this correct? I would appreciate your help on this engineering problem. Thanks, Cayroo
