Restriction gauge
Trommel
Mining
May 10, 2006
9
Guys
I have what I think is a fairly silly question about a restriction guage on an industrial diesel engine.
In the system we use, we have an outer and inner filter assembly leading to a turbocharger. In between there is a restriction indicator which sends a signal back to the engine when the filters are blocked (pressure difference between ambient and inside air intake is great enough)
I think the system works by sensing the deflection of a diaphragm.
Is this correct?
Are there any inherent problems with this system?
That's one way to do it.
A robust example is the Dwyer Magnehelic line of pressure gages/ indicators/ transducers.
Mike Halloran
Pembroke Pines, FL, USA
The problem is that pressure drop is a function of flow which is a function of engine rpm.
They are usually looking for maximum vacuum attained.
To put it another way, if the pressure drop is not significant, because the engine is not at full power, then it doesn't matter anyway.
Cheers
Greg Locock
