Help with ShowOpen() by CajunCenturion
bpeirson
CA
I searched the archives and found function ShowOpen() and function ShowSave() by CajunCenturion in thread766-100581 (Aug 2004). Both work great with a slight modification;
Code:
      .tLng_hWndOwner = Me.hWnd
      .tLng_hInstance = App.hInstance
must read
Code:
      .tLng_hWndOwner = Application.hWnd
      .tLng_hInstance = Application.hInstance
on my system.
How do I extract the filename from ShowOpen() without the entire path included in the string? I will post the code if required.
if PN contains the full path name use the following function to reverse the character order in PN
Function ReverseString(inString As String) As String
Dim lngLen As Long
lngLen = Len(inString)
If lngLen <= 1 Then
ReverseString = inString
Else
ReverseString = Right(inString, 1) _
& ReverseString(Left(inString, lngLen - 1))
End If
End Function
ie. rPN =ReverseString(PN)
now search for the first instance of "\" character using the built in function InStr, ie
iPos= InStr(1,rPN,"\")
Finally return the filename using Right function
FN=Right(PN,iPos-1)
Thanks, I was having problems resolving variable numbers of "\" in various filenames. I had resorted to pasting the full path into a worksheet and using excel functions because I am more familiar with excel than VBA. It occurred to me that someone must know a simpler way.
It's even easier using the InstrRev function. See:
(just the same for VBS or VBA)
Good Luck
johnwm
________________________________________________________
To get the best from these forums read faq731-376 before posting
Steam Engine enthusiasts:
cummings54, thanks, it works well.
johnwm, less code but it doesn't work as well. The filename returned always included the folder "Foldername\filename.dxf". I tried to change the compare options of the function but no luck.
The next phase is to predetermine the path and filename which is used to save the file with the showsave() function.
I will need to change the extension of the filename as well.
Any help is appreciated.
InstrRev has always worked for me
Code:
Public Function myFilename(ByVal fn As String) As String
myFilename = Mid$(fn, InStrRev(fn, "\") + 1)
End Function
Use as
Code:
f = "F:\My Documents\Inetpub\[URL unfurl="true"]wwwroot\wpnew\images.dxf"[/URL]
Debug.Print myFilename(f)
It produces images.dxf for me.
To change the file name use the MID$ command
Good Luck
johnwm
