thermeng2
- Jan 29, 2003
- 24
I am having problem etching any steel. In some spots it seams fine in others it blows through and in others you can't even see it. Here is what I am using. I have a 1500 watt Mazak stx48 with a 5" head and 1.5 tip. Any help would be great....!!!! Thanks
Also what does m68 do. I know it is for Enhanced pulse mode. But What does it do and how do I know when I should use it. I am useing m67 on this program but why ? M67 is High speed pulse. Should I be using m69 normal pulse..Again thanks for the help....
:1000
(ENGRAVE STEEL)
G87P00
G88P01M56
M22
G4X.01
G82P0050Q100R50M67F39
M32
M20
G88P01M56
G87P28
M99
:1000
(ENGRAVE STEEL)
G87P00
G88P01M56
M22
G4X.01
M32
M20
G88P01M56
G87P28
M99
