As long as there are no sources of pressure other than liquid level and the tank or vessel is open to the atmosphere your approach sounds valid. For piece of mind, however, have a good understanding as to how the equipment is filled, its block in potential, and its ability to "relieve" as quickly as it is filled. Venting to atmosphere is one thing but pressure will build if the vent won't pass fluid at a rate equal to or greater than the fill rate.
Normally, when a tank is designed to be only full of liquid, the "design pressure" is stated as atmospheric- it is taken as the gas pressure above the liquid, not the pressure at a specific depth in the liquid.
If the item in question is not just enormous, fittings subject to hydrostatic pressure only would normally be sized for some nominal pressure class- say, 150#- regardless of the actual pressure, which might be much lower.
Full of water means that the height of water column is acting like internal pressure on the wall and bottom junction, (P= rho x g x H = Water density kg/m3 x 9.81 m/s2 x H meters of water height). In addition, the vessel or tank may have some vapour or other gas pressure above the liquid, in which case is called "vapour space pressure" and has to be added to the "Full of Water" pressure, to establish the wall thickness calculation pressure / design pressure. If there is no additional "vapour pressure", that means the vessel or tank is vented to the atmosphere and then you call it "Atmospheric". However, the design pressure is still not zero, but water column only, without additional vapour pressure.
Cheers,
Full of water means that you calculate the pressure at the "T" joint, bottom, based on the liquid level when full, in this case water.
Be careful with the descriptive atmospheric.
Atmospheric means that you design the "T" joint, bottom of tank, based on the level when full of the product stored in the tank at atmospheric pressure based on the density of same.
All our storage tanks use the minimum value for density of 1 with others designed using the density of the product being stored. We have numerous tanks that store material with a density of 1.35 and several H2SO4 tanks using a density of 1.85
