Stainless Steel In Latching Relay 1
tomd3583
14
The core for the latching relay that I currently use is no longer made at the specs I need (vacozet 258). The coercivity is 26 Oe. I was wondering if there was a magnetic stainless steel that I can use. It has to change poles with a short current pulse and act as a weak permanent magnet after the current pulse to hold the relay latch.
I used to use Vicalloy for this application, but that was 20 years ago. There are some stainless grades that might work, but controlling coercivity is going to be trickey.
Rust never sleeps
Neither should your protection
would you happen to know where I can find vicalloy and if it is made in rod form.
