bacon4life
- Feb 4, 2004
- 1,488
When spare CT's are not used, what is the proper way to short and ground them?
1. Rely on the shorting screws in the shorting terminal block to short and ground.
2 In addition to the screws, add a jumper between the X1 and X5 terminal, thereby ensuring it is shorted even if one screw is removed.
3 In addition to the above, add another jumper between one of the terminals and ground, ensuring that if both screws are removed, it will still be grounded.
4. Something else?
Thanks in advance.
4. Something else?
Thanks in advance.
