Compatibility tables
peterpom
Hi Guys,
I have to design a small chemical mixing plant, but cannot find two of the chemicals in my tables. One is Etnanoic Acid CH3COOH and the other is Nitrile-Trimethyl-Phosphonic Acid C3H12NO9P3. In addition two other chemical are mentioned NaNO2 and NH4CI. Does anyone know about these chemicals?
Material requirements for storage and handling, health risks, fire hazard, reactions when mixed with water, etc.
Thanks for any input,
Pete.
The first one is acetic acid, just look it up.
The second one is harder but it has a CAS number 6419-19-8, Put that in Google and you should get That is 64 pages of stuff on your chemical.
The other two are sodium nitrite and ammonium chloride which are common chemicals although I am not sure if you have written NH4Cl or NH4CI . If it has an I (i) on the end I do not recognize it.
Good luck
Hi peterpom,
All these chemicals are listed in Chemical Hazards Handbook,OSHA,and the Merck Index..
Good luck
Whylie
