Pressure Vessel
reilly22
24
I have a pressure vessel that I would like to be able to probe along a line to get displacement values and stresses. Is there anyway to do this without probing each point individually? I would like to know the displacement and stress at the single wall along the inside edge. Thanks for the help.
I think the best way is to create a parting line in SW (you will have to re-mesh and re-run) in order to be able to ask results on this.
Research the topic of sensors! You can define (create) a sensors along any line in the model and request Cosmos to calculate stress at points (sensors) you specify.
