Saving Cell Array to ASCII file as delimited row and column data
Mulally
Aerospace
Jan 12, 2007
1
I have a program that loads data from a delimited file (rows and columns) into a cell array using textscan:
DAT=textscan(fid,'%s%f%f%f%f%f%f%f%f%s%f%f%f%f%f%f',nrows_file_load, 'headerlines', 2, 'delimiter',',');
I modify the first column in DAT and now want to save the modified DATA it to another file as rows and columns in a deliminted ASCII format similar to the original. In other words I want to reverse the textscan function. Any ideas would be appreciated.
Dan
Dan hi,
I suggest you to use
fid=fopen('data.txt','w')
fprintf(fid,'%s%f%f%f%f%f%f%f%f%s%f%f%f%f%f%f',nrows_file_load, 'headerlines', 2, 'delimiter',',')
fclose(fid)
It should work.
Good luck...
AAD
