pranayvarma
- Sep 1, 2005
- 7
I have an aluminum curtain wall mullion which needs to be re-inforced using steel tube. I would be inseting the tube into the mullion hollow space. Now how do i analyse this combination for strength & deflection. Do i need to connect the steel stiffener to the aluminum member at regular intervals and check for shear just like in composite structures. What about Bending Moment, how do i analyse for strength. Can i distribute the Bending Moment among the stiffener & the mullion as per ratios of their respective rigidities (EI/L).
Thanks in advance
Thanks in advance
