tlmassey
- Jan 26, 2007
- 8
I'm working on an RF (~500 MHz) impedance transformation circuit. On the chip side of the circuit, I have a 3cm microstrip transmission line connecting the 50k ohm-impedance chip to the 50k ohm-impedance side of the transformation network. The characteristic of impedance of the line is (within a factor of two or so) bound to 150 ohms.
My question is this:
Are there any tricks that I can use to make the transmission line look less like a transmission line or otherwise improve the signal coupling to the chip?
My limitations:
1) The chip is provided by another group, and cannot be changed. I'm stuck with the high impedance and small package.
2) I can't shorten the transmission line by moving the components closer, because the chip is too small to fit eight inductors and other components.
Thanks in advance for any help that you can provide!
-TMassey
My limitations:
-TMassey
