vincentpa
- Nov 9, 2005
- 223
I am modeling a truss in STAAD. When modeling the top and bottom chords where the truss web members frame into them, is it appropriate to make the top and bottom chords continuous at the nodes (without releasing the moments) and only pin the top and bottom chord at the support/column ends? Or, should I release the moments at each node? The top and bottom chords will be fabricated as continuous double angles. If I make the chords continuous, there is quite a bit of moment in them.
