Is there a criterion for determining when the lumped parameter method will work for bodies with a constant temperature or flux at the surface?
I understand the Biot criterion can be used if you can calculate a heat transfer coefficient at the surface (i.e. convective resistance dominates total resistance so that conduction in the body can be ignored), but it is not clear to me under what conditions conduction can be ignored when you have a temperature or flux at the surface, because there is only one resistance from conduction in the body. Clearly, if the body is very small and has a moderately high conductivity, you would not expect a large temperature gradient in the body, but is there a formal criterion to show this?
Thanks for any adivce.
