I would like to connect two W18 beams together using a welded connection. The web will have a full penetration weld, and the top and bottom flanges will have a certain size plate fillet welded over and centered at the interface of the two beams. It is intended to be a moment connection. My question is analyzing the fillet welds to the top flange, and analyzing the plate itself. I was going to take the moment at the connection point, and turn it into axial (compressive and tensile) loads acting on the welds and plates by dividing it by the the depth of the original beam. So say a W12x58 is the size of the beams being connected and the moment at this point is 120 in-kips, then i would use 10 kips of axial load acting on the weld. Is this the only load i need to use to determine length of weld and size of plate i need? Should I also add into account shear flow?
