S7 ETHERNET COMMUNICATIONS
jazznska
DE
Lookihg for a recommendation for an adapter that will allow me to connect to a Seimens S7 PLC (with a profibus connection) over ethernet. What products you might have used and your feedback on their suitability.
Thank you in advance,
Russ Miller
Hello;
What do you want to connect to the Profibus? If it is a PC computer, try SST/Woodhead. I have used some of their products.
jazznska
Profibus connected to industrial ethernet is known as Profinet.
The following link explains more on Profinet: For more help I would suggest advising the type of equipment you have (type of S7) as your description is a little vague in the Simatic world of S7. Also, as djs hints, what are you trying to do?
Jazz,
You can use a Siemens CP5511/CP5512 and Simatic Net PC card (plug and play) to connect via MPI or Profibus at any location on the bus. If the PLC is a soft PLC such as WinLC controller and is installed on a PC670 HMI for example, you can connect via a crossover cable and TCP/IP network connection. Regardless of the protocol you must first set up the interface via the Set PG/PC Interface from the Options tab in Step 7.
The S7-200 is different from the S7-300 and 400 series in terms of hardware and accessories. As sed2developer said, your need to start by determining which version you have.
JRaef.com
"Engineers like to solve problems. If there are no problems handily available, they will create their own problems." Scott Adams
For the best use of Eng-Tips, please click here -> faq731-376
Its been a while on siemens but I remember!
I know their was a simple special manufactured db9 connector that converts from the Siemens Profibus/programming driver to Ethernet. Costs was pretty low, $300, but that was a few years back. I am sure its still out their but better.
