vincentpa
- Nov 9, 2005
- 223
What linetype and lineweight would you for an existing structure? For plan work and details, I use a shaded (grayscale at 50%) for the existing structure and the new modifications/new structure will be regular solid lineweight. The linetype for existing plan work is a short dash and for existing in details we use a dash double dot.
What do you use for demolition? We use the structural components not to be demolished as the same as existing structure and the structural components to be demolished are bold and dashed.
What do you use for existing and demolition and what is the typical convention for existing and demolition?
