Structural05
- Feb 12, 2007
- 2
Can anyone advise me on the correct interpretation of Kz and how to apply it (Velocity pressure exposure coeffiecient)? Previously in the D100-96 standard the BCL and the top of tank were the only heights considered for calculating the pressure to use for the entire tank structure. The wording used to define qz and Kz (D100-05) lead me to believe that Kz should be calculated at the centroid of EACH MEMBER.
Bottom Line: Should I calculate Kz once using the overall tank elevation and then apply this pressure to the entire tank, Or should I calculate Kz for each individual member?
Any help with this would be much appreciated!
