I keep seeing essentially the same detail for a stepped strip footing which indicates for a vertical step of x, there needs to be a horizontal component of 2x. Shouldn't there be a limit how much of a step you can have. And having said that, how would you treat a strip footing on a hillside that is steeper than 1(V):2(H)
Thanks in advance
Thanks in advance
