calculor
- Apr 13, 2001
- 59
Have a situation where the elevator shaft in a 7 storey building is too narrow for the elevator from the 4th to 7 th floor. This is a result of a mistake by the formwork contractor. Unknown to myself, until today. the contractor started to chip 5 inches off the 10 thick wall. I'm curious if anybody has encountered this situation before. I'm considering installing 2 HSS steel columns with plates and bolting the column to the shaft walls as well as the floor top and bottom. Any comments?
