bjb
- Nov 8, 2002
- 455
I have a small one-story PEMB with an almost flat roof that I am analyzing for column reactions. For the above figure, Load cases 1 and 3 apply. For load case 3, is it necessary to add 75% of the roof pressure from the X direction to 75% of the roof pressure from the Y direction? It seems to me that this would be double dipping because the projected area of the roof does not change.
This would be contrast to the walls, where if you had wind acting concurently in the X and Y directions your projected area does increase.
