Probe Results, Sensor
reilly22
I'm having a tough time with the Probe Results command in Cosmosworks. I have a cylinder that I have probed many locations and I would like to simulate the probed locations on stress result and strain result plots. I have created the Sensor-1 that has all of my locations and even saved it to my hard drive to see that it is saved. When I go to a different plot and click "probe" and then "from Sensors" the option Sensor-1 appears but does not populate the results area. If I get out of the Probe mode and go to the pulldown menu Cosmosworks-Sensors, all of my probed values appear correctly under "locations". This is driving me crazy. Please help. Thanks.
reilly22,
i did exactly what you have described here and couldn't reproduce it. i see the values for the sensor locations after using Probe in the feature manager. i'm on SW/CW 07 SP2.
