I have a trellis that I am analyzing using RISA-3D. the trellis is comprised of a inner frame and outer frame which are welded together using intermittent fillet welds. I am wondering if it is acceptable to model rigid links at the location of the intermittent fillet welds.
Thank You,
Val Courtney, PE
Valstone Engineering, Inc.
Thank You,
Val Courtney, PE
