Yes it is blocked, the problem is the owner has a line on 7/16" material that he "has to use". So it's one of those things were the client comes to you and says I have six boxes of toothpics and some post cards can you make it work so that I can build a mansion that won't fall down , but this is all you can use. Thanks.
