0707
Petroleum
- Jun 25, 2001
- 3,339
Expansion joints are critical equipments in a FCC flue gas piping system. I am looking for any information on the use of outer pre installed clamp shells on new expansion joints. The intention of the outer clamp shell is for quick sealing weld, just in case of a flue gas leak through the inner expansion joint, avoid a big shutdown and keeping the unit running till the next big turnaround for definitive replacement of the inner expansion joint.
luis marques
