Guest
When using regenerative braking you drive the motor past synchronous speed which has a braking effect. How would you drive the motor past synchronous speed not using the load to do so. What does regenerative braking cause to happen to the motor in order to have this braking effect.
Thanking you in advance,
Ryan
Ryan
