Camber-Length Ratio
etabs2002
11
If girder got camber 2" how much that will be change lenght of the girder.
How to calculate?
Assume the centerline length along the arc stays constant. With a small camber, the change in length should be fairly negligible.
Example: With a 14,400" rolling radius and a 480" long beam, I get a 2" camber and a change in length due to curvature of 0.022".
How did you come up with 14400" for the radius? I get R=1200". Anyway, I agree the length change is megligible. Besides, once it is installed it will straighten out somewhat.
kxa,
One way is to use Pythagorean's theorem: radius²=(½ span)²+(radius-camber)² This reduces to radius=[¼span²+camber²]/[2camber].
The arc length = 2radius*asin(½span/r)
