I suspect that this thread has got very confused for two reasons. But before I explain any further let me state that I am assuming that your fluid is a gas or vapor. If it is not then stop reading now and disregard the rest of this post.
Firstly, the form of the Bernoulli equation that CJKruger and Latexman are referencing is specifically for
incompressible fluids, and if you are using a gas it will just mislead and confuse you.
Secondly, it is difficult to look at just the discharge pipe. Of course, it is not impossible to analyze the discharge pipe alone, but it is much easier to understand conceptually if you consider the entire system from the pressure vessel through to the atmosphere.
OK, so I suppose I should justify these statements.
Latexman has set out the Bernoulli Equation in detail. This form has the units of
length for each term, and this "length" is usually called the head. However, the head is in terms of the
flowing fluid and with a gas the density is constantly changing along the length of the pipe so a foot of head at the start of the pipe is
not the same as a foot of head at the discharge. With an incompressible liquid the density does not change and you can add the various terms involving head, but with a vapor you are adding apples and oranges. If you multiply each term of the equation by (Density x Gravity) then you convert each term to pressure units and then you can add them because you will have applied different densities at each point.
Also, I don't agree with Latexman's statement h
L = V
12/(2g). When we calculate the pressure drops in pipes we often take the inlet and outlet losses into account this way by lumping them in with the friction calc (i.e. Darcy-Weisbach), but what we are really doing is applying a partial form of Bernoulli. In my understanding h
L is specifically the frictional resistance and the V
12 term is taken care of separately in Bernoulli. In my opinion, Latexman is taking the V
12 term into account twice, plus he is getting the signs confused and therefore they seem to cancel each other out. I would not do it that way.
CJKruger makes a very important poing by saying "But remember, this pressure gets converted to velocity at the inlet, and is only "lost" at the exit". This is true of liquids, but does not tell the whole story for gases. Naturally a portion of the pressure energy is converted to velocity at the inlet when gases are involved. But as the gas flows along the pipe and the pressure decreases the gas expands and
the velocity continues to increase and this consumes energy. This requires a modified version of Bernoulli and as the math is a bit hairy for an old man like me I will leave it to you to check in your favorite text book! The outcome of this modified treatment is an equation like 1-6 in Crane TP410 (which is expressed in terms of pressure and not head for the reason I explained above).
Now let us consider the overall system in order to put the discharge pipe into context. If we assume the pressure vessel is large enough that we can regard the gas velocity in the vessel as zero, then we can regard the pressure energy in the vessel alone as supplying the energy for the following aspects
a) forcing the gas into the outlet nozzle (i.e. the inlet loss)
b) overcoming friction in the pipe between the vessel and the valve
c) overcoming the pressure drop through the valve
d) overcoming friction in the pipe between the valve and the atmosphere
e) accelerating the gas from zero to its final velocity at the exit. (i.e the exit loss)
You really need to look at this overall system in checking your valve. If you want to look at the discharge pipe alone you would have to take the velocity at the start of the discharge pipe into account, because the gas contains both kinetic and pressure energy at this point. Your acceleration term would then take into account only the increase in velocity from the start to the end of the discharge pipe.
If you have read this long story all the way through, then I guess you deserve an answer to your original question. Yes, you absolutely
cannot disregard the gas velocity in sizing PSV piping. But if you are looking specifically at the discharge piping remember to take only the velocity difference from the valve's outlet flange to the end of the pipe into account. The losses in terms of changes of direction, acceleration, etc
inside the valve will be taken care of in the Cv of the valve.
Katmar Software
Engineering & Risk Analysis Software
