matlab gui
liana81
Hello to everyone, i am a newbie in this forum as well as in matlab programming, that's why my question is simple.
I have made with Guide a panel which has 10 pushbuttons, one for each number between 0-9.When i press a button i.e. the 1,i want this number to be displayed.When i press the button 2, the number 2 must be displayed e.t.c.Generally all the numbers must be displayed from the beginning.I have understood that this can be done with the callback of each pussbutton,but i 'don't know how.What commands should i use;
If anyone helped me, i would be really grateful..
Lets say that you have 1 text box where you want to display the number of the selected pushbutton called textbox1.
First, remove the panel and put all of the pushbuttons in a button group. You can do it the other way but it is more of a pain. Lets call the button group pushbtngrp (and the pushbuttons pb0 - pb9). Then the following code should do what you want:
function pushbtngrp_SelectionChangeFcn(hObject, eventdata, handles)
selection = get(handles.pushbtngrp,'SelectedObject');
switch get(selection,'Tag')
case 'pb0'
value = 0;
case 'pb1'
value = 1;
case 'pb2'
value = 2;
end
set(handles.textbox1,'String',value);
hope this helps...
First of all,thank you for your answer.Secondly,when you say textbox,which component do you mean;The edit text;Do i have to write something in its callback;Or just the code you gave me;
I don't know much about guide and unfortunatelly i don't have the time to learn it.So excuse me if my questions are fullish..:)
