Boiler8019
Geotechnical
- Mar 4, 2007
- 46
Who is ultimately responsibile for the durability and strength of concrete? Just the material itself, not the design of reinforced beams slabs etc. Typically, a concrete supplier puts together a mix design and submits it to the engineer per ACI procedures for approval. I have a contractor sending me RFI's asking if adding retarder to the mix and placing a vapor barrier below is acceptable to extend workability for a set of stairs on grade.
I feel it's the concrete suppliers responsibility to advise the contractor on something like this. All Im concerned about is achieving the final strength and durability.
How do you typically respond?
