ckar
- Feb 26, 2007
- 10
i need to support a new metal joist floor on existing two-wythe exterior solid brick wall with an air cavity. the two wythes are bonded together with brick units in what i think is called common bond pattern. the wall is only 8" thick. the building is two story high and was built in 1950's. I am using marino joists that are connected to a joist track and the track will connect to the wall. Hilti recommends adhesive anchors which i do not like very much because of their loss of strength in case of fire. Any ideas to the kind of anchors to use?
