SHBH
- Mar 23, 2007
- 55
I was checking cl 12.4.2.3 for seismic load combinations, in which 0.2Sds is used to account for the seismic load in vertical direction. For rest of the horizontal seismic loads , one can use 100% in X dir and 30% in Z dir (seismic design cat D).
What if 100% is in the vertical direction, should it then be 100%Vertical + 30% hor-X + 30%hor-Z
I have seen this combination to be used in some other design offices, but where is the ref in code.
