Hi all, I'm a new member with a pretty basic design question. When designing the bottom slab of a buried tank which will be subject to uplift due to high groundwater, do I add the uplift force to the soil pressure due to gravity loads or subtract it? For example, If I have a 10 ft. by 10 ft. tank that carries a total gravity load of 100,000# I will have a design soil pressure on the bottom slab of 100,000#/100sq.ft.= 1000 psf. Now, if I have a groundwater table that is 10 ft. above the bottom of my tank I will have an uplift force of 10x62.4= 624psf. Will my total design load for the bottom slab be 1000psf + 624psf= 1624psf or 1000psf - 624psf= 376psf???
Thanks!
Thanks!
