Graph help
vinsen
I have a data of a two compressor speeds and i have to create another matrix for every 5 hrs another variable for the comp speed.
then i plot the graph with x axis compressor speed and the difference of this speeds in the y axis for every 5hrs and then i have to take a data from a point for example if i have to take a data of a point from the graph for speed 8000 rpm in the graph which contains the compressor speed difference, how can i take it from the graph.
